本指南有最近更改,您可查看未经巡查的最新版本。
简介
The Asus X551CA spacer keeps the laptop light weight and stable, but also provides the owner with the option to instal an optical drive.
你所需要的
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
4等其他人完成本指南。
