跳转到主内容
Asus X551CA Front Display Bezel Replacement
你所需要的
  1. Asus X551CA Front Display Bezel Replacement, Keyboard Plate Cover: 步骤 1 中的图像 1,1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Front Display Bezel Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Front Display Bezel Replacement: 步骤 3 中的图像 1,1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Front Display Bezel Replacement: 步骤 4 中的图像 1,3 Asus X551CA Front Display Bezel Replacement: 步骤 4 中的图像 2,3 Asus X551CA Front Display Bezel Replacement: 步骤 4 中的图像 3,3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Front Display Bezel Replacement: 步骤 5 中的图像 1,1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Front Display Bezel Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Asus X551CA Front Display Bezel Replacement: 步骤 7 中的图像 1,1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Asus X551CA Front Display Bezel Replacement: 步骤 8 中的图像 1,1
    • Once it is free, remove the hard drive from its internal cavity.
  9. Asus X551CA Front Display Bezel Replacement, Spacer: 步骤 9 中的图像 1,1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  10. Asus X551CA Front Display Bezel Replacement: 步骤 10 中的图像 1,1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
  11. Asus X551CA Front Display Bezel Replacement, WiFi Card: 步骤 11 中的图像 1,1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
  12. Asus X551CA Front Display Bezel Replacement: 步骤 12 中的图像 1,1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
  13. Asus X551CA Front Display Bezel Replacement: 步骤 13 中的图像 1,1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
  14. Asus X551CA Front Display Bezel Replacement, Battery: 步骤 14 中的图像 1,1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
  15. Asus X551CA Front Display Bezel Replacement, Motherboard: 步骤 15 中的图像 1,1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
  16. Asus X551CA Front Display Bezel Replacement: 步骤 16 中的图像 1,2 Asus X551CA Front Display Bezel Replacement: 步骤 16 中的图像 2,2
    • Now, locate the two wires connected to the motherboard.
  17. Asus X551CA Front Display Bezel Replacement: 步骤 17 中的图像 1,2 Asus X551CA Front Display Bezel Replacement: 步骤 17 中的图像 2,2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
  18. Asus X551CA Front Display Bezel Replacement: 步骤 18 中的图像 1,2 Asus X551CA Front Display Bezel Replacement: 步骤 18 中的图像 2,2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
  19. Asus X551CA Front Display Bezel Replacement: 步骤 19 中的图像 1,1
    • Remove the motherboard from the case by gently lifting it upward.
  20. Asus X551CA Front Display Bezel Replacement, Front Display Bezel: 步骤 20 中的图像 1,1
    • Locate both of the hinges that connect the monitor to the bottom plate cover.
  21. Asus X551CA Front Display Bezel Replacement: 步骤 21 中的图像 1,2 Asus X551CA Front Display Bezel Replacement: 步骤 21 中的图像 2,2
    • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
  22. Asus X551CA Front Display Bezel Replacement: 步骤 22 中的图像 1,1
    • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
  23. Asus X551CA Front Display Bezel Replacement: 步骤 23 中的图像 1,1
    • Locate the two stickers that cover up the screws that hold the front bezel in place
  24. Asus X551CA Front Display Bezel Replacement: 步骤 24 中的图像 1,2 Asus X551CA Front Display Bezel Replacement: 步骤 24 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove these stickers.
    • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
  25. Asus X551CA Front Display Bezel Replacement: 步骤 25 中的图像 1,1
    • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
  26. Asus X551CA Front Display Bezel Replacement: 步骤 26 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
  27. Asus X551CA Front Display Bezel Replacement: 步骤 27 中的图像 1,2 Asus X551CA Front Display Bezel Replacement: 步骤 27 中的图像 2,2
    • Once the screws are taken out, the front bezel is ready to be removed.
    • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Gently use hands if necessary to separate the front bezel from the back.
  28. Asus X551CA Front Display Bezel Replacement: 步骤 28 中的图像 1,1
    • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
结论
5等其他人完成本指南。
Josh
于04/10/14注册
2,958 声望
创作了12篇指南
团队
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G22
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 4,398
