跳转到主内容
Asus X550ZA-SA100603E RAM Replacement
  1. Asus X550ZA-SA100603E RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them. Make sure to keep the screws for reassembly.
  2. Asus X550ZA-SA100603E RAM Replacement: 步骤 2 中的图像 1,1
    • Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
  3. Asus X550ZA-SA100603E RAM Replacement: 步骤 3 中的图像 1,1
    • Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
  4. Asus X550ZA-SA100603E RAM Replacement: 步骤 4 中的图像 1,2 Asus X550ZA-SA100603E RAM Replacement: 步骤 4 中的图像 2,2
    • The motherboard is the big board on the left-hand side of the internals. Remove all bordering screws that hold the motherboard in place.
  5. Asus X550ZA-SA100603E RAM Replacement: 步骤 5 中的图像 1,2 Asus X550ZA-SA100603E RAM Replacement: 步骤 5 中的图像 2,2
    • Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
  6. Asus X550ZA-SA100603E RAM Replacement: 步骤 6 中的图像 1,1
    • Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot. Push until you hear a clicking noise.
结论
另外一个人完成了本指南。
Paul Flynn
于01/14/19注册
16 声望
创作了2篇指南
团队
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S5G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 316
