跳转到主内容
Asus X550ZA-SA100603E Keyboard Replacement
你所需要的
  1. Asus X550ZA-SA100603E Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Keyboard Replacement: 步骤 2 中的图像 1,3 Asus X550ZA-SA100603E Keyboard Replacement: 步骤 2 中的图像 2,3 Asus X550ZA-SA100603E Keyboard Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Keyboard Replacement: 步骤 3 中的图像 1,3 Asus X550ZA-SA100603E Keyboard Replacement: 步骤 3 中的图像 2,3 Asus X550ZA-SA100603E Keyboard Replacement: 步骤 3 中的图像 3,3
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Keyboard Replacement: 步骤 4 中的图像 1,3 Asus X550ZA-SA100603E Keyboard Replacement: 步骤 4 中的图像 2,3 Asus X550ZA-SA100603E Keyboard Replacement: 步骤 4 中的图像 3,3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the keyboard.
结论
2等其他人完成本指南。
一条评论
Hello
May I know how to plug in the keyboard ribbon cable (the big one)?
I've tried to push the white clamp before plugging the cable, but it is stuck (it cannot be completely plugged in), and it can be easily removed as if the cable is not locked.
Thanks in advance.
Kurisada Santo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 953
