跳转到主内容
Asus X550ZA-SA100603E Hard Drive Replacement
你所需要的
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: 步骤 2 中的图像 1,1
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
结论
2等其他人完成本指南。
Paul Flynn
于01/14/19注册
16 声望
创作了2篇指南
团队
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S5G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 421
