跳转到主内容
Asus X550ZA-SA100603E Battery Replacement
你所需要的
  1. Asus X550ZA-SA100603E Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Battery Replacement: 步骤 2 中的图像 1,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 2 中的图像 2,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Battery Replacement: 步骤 3 中的图像 1,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 3 中的图像 2,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 3 中的图像 3,3
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Battery Replacement: 步骤 4 中的图像 1,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 4 中的图像 2,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 4 中的图像 3,3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Battery Replacement, Battery: 步骤 6 中的图像 1,2 Asus X550ZA-SA100603E Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Battery Replacement: 步骤 7 中的图像 1,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 7 中的图像 2,3 Asus X550ZA-SA100603E Battery Replacement: 步骤 7 中的图像 3,3
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
结论
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 6,094
