本指南有最近更改,您可查看未经巡查的最新版本。
简介
In this guide, you can replace/upgrade the RAM inside your ASUS X550CA to give it a bit more performance.
你所需要的
Please make sure that your computer is fully Shut Down, so that the lights on the bottom of the computer are all of (Picture 2) and the Power Cord is unplugged.
Spread the 2 clips on each side of the battery out, the one on the right should lock, and you will need to hold the one on the left while you pull the battery out. See the pictures for more details.
You now need to use a screwdriver. I use the PH00 head of the iFixit 64 Bit driver kit.
There are 2 screws on each side of the bottom of the computer. These are above the bottom 2 feet. They are quite long.
The bottom is held on by clips. Pull back and then up to remove the plastic shell.
To take out the RAM, locate the RAM Stick (SODIMM) towards the right of the computer. Spread the clips on either side of the stick and the RAM stick should pop up. You can then pull out, and replace.
To reinstall, insert the new RAM stick at a slight angle (about 45 degrees). Push in and down to seat the RAM Correctly. Then just install the back panel.
5等其他人完成本指南。
2条评论
What is maximum memory for an ASUS X550CA?
Mine came standard with 8GB, and I found that one of the sticks was soldered to the motherboard. I think it only takes 8GB sticks, so therefore the maximum memory is 12GB.
Leo Carr -
