跳转到主内容
Asus X54C Keyboard Replacement
你所需要的
视频概述
  1. Asus X54C Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Asus X54C Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Disconnect the charger and switch off the laptop.
    • Two keys keep locked battery.
  2. Asus X54C Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,3 Asus X54C Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,3 Asus X54C Keyboard Replacement, Keyboard: 步骤 2 中的图像 3,3
    • The Keyboard is held by 5x locking clips.
    • Use a tool with with a thin tip and lift slightly the KB from the left side.
    • Unlock clips one by one.
    • Disconnect the KB ribbon cable.
结论
9等其他人完成本指南。
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
2条评论
Thanks for the detailed vid! What are the materials used at 07:00-08:00 to clean and replace the paste? Specifically what's in the spray bottle and the syringe
Buster Cluster - 回复
Hello,
To clean the thermal paste, the author used a soft toothbrush (probably with isopropyllic alcohol).
The syringe contains a non-conductive thermal paste.
You can replace the toothbrush by cell polyurethane foam swabs and isopropilic alcohol to remove the old thermal paste if you want.
This is a laptop with a CPU that doesn't heat too much, so you can replace the original thermal paste by any non conductive thermal paste made to be used in computers it will be fine.
Brendan -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 6,539
