跳转到主内容
Asus X540S panel Disassembly
你所需要的
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S panel Disassembly: 步骤 2 中的图像 1,1
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S panel Disassembly: 步骤 3 中的图像 1,3 Asus X540S panel Disassembly: 步骤 3 中的图像 2,3 Asus X540S panel Disassembly: 步骤 3 中的图像 3,3
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
结论
13等其他人完成本指南。
Padraic Hoselton
于08/22/17注册
4,180 声望
创作了12篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,541篇指南
3条评论
Feels like the panel is glued on mine. all screws are out, corners are loose but rest feels glued. anybody have advice? I dont have access to a heatgun
Non Gerrell - 回复
Well the first time I did it I had to give it a bit more pressure and loosen it up on all the sides. Because it should only be snapped in place. I don’t remember mine having glue the first time but I do remember I needed pry tools to get it off. I used some ifixit spudgers.
Padraic Hoselton -
I used a plastic card (like credit card) to slide between the panels along the edge - it went smooth!
Alexey Sazonov -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 58
总计 10,137
