跳转到主内容
修复你的物品
维修的权力
商店
简介
If the laptop gets dropped or bumped too hard the webcam cables may become disconnected or the webcam may break. This guide will show you how to replace it.
  1. Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame. Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
    • Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
  2. Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
    • Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
    • The screws are 20 mm in diameter and 50 mm long.
  3. Using the plastic opening tool, pry the screen frame away from the screen.
    • Using the plastic opening tool, pry the screen frame away from the screen.
  4. Using your hands, grasp the screen frame at it's base near the laptop hinge.
    • Using your hands, grasp the screen frame at it's base near the laptop hinge.
    • While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
    • The space between the screen frame and laptop hinge is very small and the plastic for both parts is weak. However, a fair amount of force is required to disconnect the screen frame from the laptop hinge. Be careful during this step, or either of these plastic pieces may break.
  5. Using tweezers, unplug the webcam wire from the webcam.
    • Using tweezers, unplug the webcam wire from the webcam.
    • If this wire was already disconnected, that may be the cause of the webcam not functioning. Try reconnecting this wire and reassembling to see if the problem is resolved before continuing.
  6. Using fingers or tweezers, pry the webcam from the laptop.
    • Using fingers or tweezers, pry the webcam from the laptop.
    • The webcam is only secured with adhesive.
结论
Gregory Browne
于2017年10月19日注册
501 信誉积分
创作了5篇指南
团队
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 UMass Dartmouth, Team S3-G5, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G5
2 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 22
总计 192
