跳转到主内容
Asus X502CA-BCL0901D Screen Frame Replacement
你所需要的
  1. Asus X502CA-BCL0901D Screen Frame Replacement, Screen Frame: 步骤 1 中的图像 1,2 Asus X502CA-BCL0901D Screen Frame Replacement, Screen Frame: 步骤 1 中的图像 2,2
    • Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
  2. Asus X502CA-BCL0901D Screen Frame Replacement: 步骤 2 中的图像 1,1
    • Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
    • The screws are 20 mm in diameter and 50 mm long.
  3. Asus X502CA-BCL0901D Screen Frame Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, pry the screen frame away from the screen.
  4. Asus X502CA-BCL0901D Screen Frame Replacement: 步骤 4 中的图像 1,1
    • Using your hands, grasp the screen frame at it's base near the laptop hinge.
    • While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
    • The space between the screen frame and laptop hinge is very small and the plastic for both parts is weak. However, a fair amount of force is required to disconnect the screen frame from the laptop hinge. Be careful during this step, or either of these plastic pieces may break.
结论
Gregory Browne
于10/19/17注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 UMass Dartmouth, Team S3-G5, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G5
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 645
