跳转到主内容
Asus X502CA-BCL0901D Battery Replacement
你所需要的
  1. Asus X502CA-BCL0901D Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the laptop over so that it is upside down.
  2. Asus X502CA-BCL0901D Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the 11 screws from the bottom of the laptop with the Phillips #00 screwdriver.
    • All the screws are 20 mm in diameter. The 4 screws that are furthest from the hinge are 50 mm long, the other 7 are 90 mm long.
  3. Asus X502CA-BCL0901D Battery Replacement: 步骤 3 中的图像 1,2 Asus X502CA-BCL0901D Battery Replacement: 步骤 3 中的图像 2,2
    • Use the Plastic Opening Tool to pry the keyboard assembly away from the rest of the laptop.
    • Take care not to lift the keyboard assembly to far away from the laptop as there are short cables that need to be disconnected first.
  4. Asus X502CA-BCL0901D Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
  5. Asus X502CA-BCL0901D Battery Replacement: 步骤 5 中的图像 1,2 Asus X502CA-BCL0901D Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the keyboard assembly away from the remainder of the laptop.
  6. Asus X502CA-BCL0901D Battery Replacement, Battery: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Unplug the battery from the laptop with the tweezers.
    • If the battery is not unplugged, the motherboard may shock you.
  7. Asus X502CA-BCL0901D Battery Replacement: 步骤 7 中的图像 1,2 Asus X502CA-BCL0901D Battery Replacement: 步骤 7 中的图像 2,2
    • Using the Phillips #00 screwdriver, unscrew the 6 screws holding the battery in place.
    • Each screw is 50 mm in length and 15 mm in diameter.
  8. Asus X502CA-BCL0901D Battery Replacement: 步骤 8 中的图像 1,1
    • Lift the battery out of the laptop.
结论
Gregory Browne
于10/19/17注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 UMass Dartmouth, Team S3-G5, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G5
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 310
