跳转到主内容
Asus X502C-RB01 Fan Replacement
你所需要的
  1. Asus X502C-RB01 Fan Replacement, Keyboard Panel: 步骤 1 中的图像 1,1
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Fan Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Fan Replacement: 步骤 3 中的图像 1,2 Asus X502C-RB01 Fan Replacement: 步骤 3 中的图像 2,2
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Fan Replacement: 步骤 4 中的图像 1,2 Asus X502C-RB01 Fan Replacement: 步骤 4 中的图像 2,2
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 Fan Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 Fan Replacement: 步骤 8 中的图像 1,1
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
  9. Asus X502C-RB01 Fan Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
  10. Asus X502C-RB01 Fan Replacement: 步骤 10 中的图像 1,1
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
  11. Asus X502C-RB01 Fan Replacement: 步骤 11 中的图像 1,2 Asus X502C-RB01 Fan Replacement: 步骤 11 中的图像 2,2
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
  12. Asus X502C-RB01 Fan Replacement: 步骤 12 中的图像 1,1
    • Gently lift the motherboard out of the casing.
  13. Asus X502C-RB01 Fan Replacement, Fan: 步骤 13 中的图像 1,1
    • Flip the motherboard over so the fan is right side up.
  14. Asus X502C-RB01 Fan Replacement: 步骤 14 中的图像 1,1
    • Disconnect the fan from the motherboard by pulling the power cable connector.
  15. Asus X502C-RB01 Fan Replacement: 步骤 15 中的图像 1,1
    • Remove the two 5.5mm screws using a Phillips #0 head screwdriver.
  16. Asus X502C-RB01 Fan Replacement: 步骤 16 中的图像 1,1
    • Detach the tape that connects the fan to the heatsink.
  17. Asus X502C-RB01 Fan Replacement: 步骤 17 中的图像 1,1
    • Lift the fan off to remove it from the motherboard.
结论
2等其他人完成本指南。
Frances Tan
于01/19/17注册
143 声望
撰写一个指南
团队
UC Davis, Team 1-5, Rodger Winter 2017 UC Davis, Team 1-5, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G5
4 名成员
创作了6篇指南
一条评论
Great guide. Re: STEP 11 - my Asus notebook had 5 screws securing the mb.
u1oo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 797
