跳转到主内容
Asus X502C-RB01 CMOS Battery Replacement
你所需要的
  1. Asus X502C-RB01 CMOS Battery Replacement, Keyboard Panel: 步骤 1 中的图像 1,1
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 CMOS Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 CMOS Battery Replacement: 步骤 3 中的图像 1,2 Asus X502C-RB01 CMOS Battery Replacement: 步骤 3 中的图像 2,2
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 CMOS Battery Replacement: 步骤 4 中的图像 1,2 Asus X502C-RB01 CMOS Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 CMOS Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 CMOS Battery Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 CMOS Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 CMOS Battery Replacement: 步骤 8 中的图像 1,1
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
  9. Asus X502C-RB01 CMOS Battery Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
  10. Asus X502C-RB01 CMOS Battery Replacement: 步骤 10 中的图像 1,1
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
  11. Asus X502C-RB01 CMOS Battery Replacement: 步骤 11 中的图像 1,2 Asus X502C-RB01 CMOS Battery Replacement: 步骤 11 中的图像 2,2
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
  12. Asus X502C-RB01 CMOS Battery Replacement: 步骤 12 中的图像 1,1
    • Gently lift the motherboard out of the casing.
  13. Asus X502C-RB01 CMOS Battery Replacement, CMOS Battery: 步骤 13 中的图像 1,1
    • Flip over the motherboard so that the CMOS battery is now visible.
  14. Asus X502C-RB01 CMOS Battery Replacement: 步骤 14 中的图像 1,1
    • Wedge the spudger tool under the CMOS battery as pictured.
    • Lift up the CMOS battery. The battery should pop out easily.
  15. Asus X502C-RB01 CMOS Battery Replacement: 步骤 15 中的图像 1,1
    • Insert the new CMOS battery (positive side up) into the slot using your finger.
结论
Jaspal Chauhan
于01/19/17注册
491 声望
创作了4篇指南
团队
UC Davis, Team 1-5, Rodger Winter 2017 UC Davis, Team 1-5, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,808
