跳转到主内容
Asus X501A-RH31 Motherboard Replacement
你所需要的
  1. Asus X501A-RH31 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Motherboard Replacement: 步骤 2 中的图像 1,1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement: 步骤 3 中的图像 2,2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Motherboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Motherboard Replacement: 步骤 6 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Motherboard Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Motherboard Replacement, Fan: 步骤 9 中的图像 1,1
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Motherboard Replacement: 步骤 11 中的图像 1,3 Asus X501A-RH31 Motherboard Replacement: 步骤 11 中的图像 2,3 Asus X501A-RH31 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 Motherboard Replacement: 步骤 13 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 Motherboard Replacement: 步骤 14 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 Motherboard Replacement: 步骤 15 中的图像 1,1
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 Motherboard Replacement: 步骤 16 中的图像 1,3 Asus X501A-RH31 Motherboard Replacement: 步骤 16 中的图像 2,3 Asus X501A-RH31 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 Motherboard Replacement: 步骤 17 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 Motherboard Replacement: 步骤 18 中的图像 1,2 Asus X501A-RH31 Motherboard Replacement: 步骤 18 中的图像 2,2
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
结论
另外一个人完成了本指南。
Romana Hruby
于10/20/17注册
587 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 UMass Dartmouth, Team S3-G3, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,203
