跳转到主内容
Asus X401A Trackpad Replacement
你所需要的
  1. Asus X401A Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,2 Asus X401A Trackpad Replacement, Trackpad: 步骤 1 中的图像 2,2
    • Working on your device while it is turned on may result in electric shock. Shut down and unplug your device before starting repair.
    • Turn over laptop and remove the battery for ease of replacement.
  2. Asus X401A Trackpad Replacement: 步骤 2 中的图像 1,3 Asus X401A Trackpad Replacement: 步骤 2 中的图像 2,3 Asus X401A Trackpad Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips Head #1 screwdriver to unscrew the eight 3mm screws.
    • Use a Phillips head #1 screwdriver to unscrew the two 4mm screws.
  3. Asus X401A Trackpad Replacement: 步骤 3 中的图像 1,3 Asus X401A Trackpad Replacement: 步骤 3 中的图像 2,3 Asus X401A Trackpad Replacement: 步骤 3 中的图像 3,3
    • Use a plastic spudger to pry off the front cover of the keyboard.
    • Do not jerk the keyboard cover off as there are ribbon cables that need to be disconnected.
    • When reassembling, there will be loud clicking to indicate you have snapped the keyboard cover into place correctly.
  4. Asus X401A Trackpad Replacement: 步骤 4 中的图像 1,2 Asus X401A Trackpad Replacement: 步骤 4 中的图像 2,2
    • Removing the white wiring from the trackpad.
    • Continue removing the wire until you get to the end.
    • Fold up the latch on the where the cable meets the motherboard.
    • Be careful not to damage any wiring during this process.
    • When reassembling, slide ribbon cable in up to black line.
  5. Asus X401A Trackpad Replacement: 步骤 5 中的图像 1,2 Asus X401A Trackpad Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to lift the ZIF connector tabs up.
    • Remove the black and the white ribbon cable.
    • Remove the entire keyboard covering.
  6. Asus X401A Trackpad Replacement: 步骤 6 中的图像 1,1
    • Lay the keyboard cover down with the keys facing down. This component contains the track pad. You will be working with this component until you reassemble.
  7. Asus X401A Trackpad Replacement: 步骤 7 中的图像 1,1
    • Begin peeling up the clear tape located on top of the band aid seal.
  8. Asus X401A Trackpad Replacement: 步骤 8 中的图像 1,2 Asus X401A Trackpad Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Using a PH0 Phillips Screwdriver, remove the two screws located within the circles of the band aid seal.
    • These screws are small. Be sure to place them on your magnetic mat.
  9. Asus X401A Trackpad Replacement: 步骤 9 中的图像 1,2 Asus X401A Trackpad Replacement: 步骤 9 中的图像 2,2
    • Begin peeling back the band aid tape. Use the plastic spudger if necessary. This will allow you to free up the trackpad.
    • Only pull the tape back to the seam and no further.
  10. Asus X401A Trackpad Replacement: 步骤 10 中的图像 1,2 Asus X401A Trackpad Replacement: 步骤 10 中的图像 2,2
    • Remove the faulty trackpad gently.
结论
2等其他人完成本指南。
Lesley Pfening
于02/07/17注册
360 声望
创作了2篇指南
团队
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 的会员
OSU-WILDER-S17S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 1,045
