跳转到主内容
Asus X401A Processor Replacement
你所需要的
  1. Asus X401A Processor Replacement, Processor: 步骤 1 中的图像 1,2 Asus X401A Processor Replacement, Processor: 步骤 1 中的图像 2,2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: 步骤 2 中的图像 1,3 Asus X401A Processor Replacement: 步骤 2 中的图像 2,3 Asus X401A Processor Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: 步骤 3 中的图像 1,3 Asus X401A Processor Replacement: 步骤 3 中的图像 2,3 Asus X401A Processor Replacement: 步骤 3 中的图像 3,3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: 步骤 4 中的图像 1,3 Asus X401A Processor Replacement: 步骤 4 中的图像 2,3 Asus X401A Processor Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: 步骤 5 中的图像 1,1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: 步骤 7 中的图像 1,2 Asus X401A Processor Replacement: 步骤 7 中的图像 2,2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: 步骤 8 中的图像 1,1
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: 步骤 9 中的图像 1,3 Asus X401A Processor Replacement: 步骤 9 中的图像 2,3 Asus X401A Processor Replacement: 步骤 9 中的图像 3,3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: 步骤 10 中的图像 1,2 Asus X401A Processor Replacement: 步骤 10 中的图像 2,2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: 步骤 11 中的图像 1,2 Asus X401A Processor Replacement: 步骤 11 中的图像 2,2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: 步骤 12 中的图像 1,3 Asus X401A Processor Replacement: 步骤 12 中的图像 2,3 Asus X401A Processor Replacement: 步骤 12 中的图像 3,3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
结论
2等其他人完成本指南。
Tyler Stiles
于02/07/17注册
152 声望
撰写一个指南
团队
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 的会员
OSU-WILDER-S17S1G4
4 名成员
创作了5篇指南
一条评论
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 1,794
