跳转到主内容
Asus X202E-UH31T Cooling Fan Replacement
你所需要的
  1. Asus X202E-UH31T Cooling Fan  Replacement, Cooling Fan: 步骤 1 中的图像 1,1
    • Remove the 9 1.2mm phillips head screws off the back of the computer using the small phillips head screw driver. Start by disconnecting the battery cable/ribbon.
  2. Asus X202E-UH31T Cooling Fan  Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open with your fingers
  3. Asus X202E-UH31T Cooling Fan  Replacement: 步骤 3 中的图像 1,1
    • Locate the fan and take out the 5 1.2mm phillips head screws with the ifixit #0 small phillips head screw driver that hold the fan to the mother board.
    • Remove the fan and unplug the cable connector that connects the fan to the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 761
