跳转到主内容
Asus X202E-UH31T Battery Replacement
你所需要的
  1. Asus X202E-UH31T Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
  2. Asus X202E-UH31T Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
  3. Asus X202E-UH31T Battery Replacement: 步骤 3 中的图像 1,1
    • Once the back is off the device, unscrew the 7 1.2mm phillips head screws that hold the battery in place using a small phillips head screw driver
  4. Asus X202E-UH31T Battery Replacement: 步骤 4 中的图像 1,1
    • Once the screws holding the battery are out, use the plastic opening tool to disconnect the battery cable ribbon from the motherboard
  5. Asus X202E-UH31T Battery Replacement: 步骤 5 中的图像 1,1
    • After replacing the battery, attach the wire ribbon to the motherboard and screw the designated screws back into the battery to secure it
结论
To reassemble your device, follow these steps in reverse order.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,427
