跳转到主内容
Asus X200MA Trackpad Replacement
你所需要的
  1. Asus X200MA Trackpad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: 步骤 2 中的图像 1,1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Trackpad Replacement: 步骤 3 中的图像 1,1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Trackpad Replacement, Trackpad: 步骤 4 中的图像 1,2 Asus X200MA Trackpad Replacement, Trackpad: 步骤 4 中的图像 2,2
    • Use the spudger to lift up and remove the black plastic covering.
  5. Asus X200MA Trackpad Replacement: 步骤 5 中的图像 1,1
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  6. Asus X200MA Trackpad Replacement, Mouse: 步骤 6 中的图像 1,1
    • Remove wider blue strip with tweezers.
  7. Asus X200MA Trackpad Replacement: 步骤 7 中的图像 1,1
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: 步骤 8 中的图像 1,1
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  9. Asus X200MA Trackpad Replacement: 步骤 9 中的图像 1,2 Asus X200MA Trackpad Replacement: 步骤 9 中的图像 2,2
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
结论
另外一个人完成了本指南。
Vanessa Garcia
于01/22/15注册
1,763 声望
创作了6篇指南
团队
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G24
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 10
总计 2,102
