跳转到主内容
Asus X200MA Speaker Replacement
你所需要的
  1. Asus X200MA Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Speaker Replacement: 步骤 2 中的图像 1,1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Speaker Replacement: 步骤 3 中的图像 1,1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Disconnect the gold cap that connects to a black wire using the metal spudger.
  5. Asus X200MA Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic component from the clip by gently pulling it back.
  6. Asus X200MA Speaker Replacement: 步骤 6 中的图像 1,2 Asus X200MA Speaker Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to free the speaker from the plastic clips.
    • Use a finger to lift the speaker and break the bond between the adhesive on the base plate and the speaker.
  7. Asus X200MA Speaker Replacement: 步骤 7 中的图像 1,3 Asus X200MA Speaker Replacement: 步骤 7 中的图像 2,3 Asus X200MA Speaker Replacement: 步骤 7 中的图像 3,3
    • Use the tweezers to carefully lift the wires from the plastic clips.
  8. Asus X200MA Speaker Replacement: 步骤 8 中的图像 1,2 Asus X200MA Speaker Replacement: 步骤 8 中的图像 2,2
    • Use the metal tweezers to free the speaker from the plastic clips.
    • Use the metal spudger to break the bond between the base plate adhesive and the speaker.
    • Lift the speakers and remove them from the base plate.
结论
To reassemble your device, follow these instructions in reverse [#|order].
Alli Krininger
于11/11/19注册
391 声望
创作了3篇指南
团队
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019 的会员
IUPUI-STELLA-F19S2G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 533
