简介
This guide provides step-by-step instructions on the replacement of the speaker of ASUS X200MA. This guide can be used to replace broken speakers or upgrade on this laptop. Use caution when removing the wires and removing the glued speakers with a spudger, as these are delicate processes.
你所需要的
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
即将完成!
To reassemble your device, follow these instructions in reverse [#|order].
结论
