跳转到主内容
Asus X200MA Motherboard Replacement
你所需要的
  1. Asus X200MA Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: 步骤 2 中的图像 1,1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: 步骤 4 中的图像 1,1
  5. Asus X200MA Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: 步骤 6 中的图像 1,1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: 步骤 8 中的图像 1,1
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: 步骤 9 中的图像 1,1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: 步骤 10 中的图像 1,2 Asus X200MA Motherboard Replacement: 步骤 10 中的图像 2,2
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: 步骤 11 中的图像 1,2 Asus X200MA Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: 步骤 13 中的图像 1,2 Asus X200MA Motherboard Replacement: 步骤 13 中的图像 2,2
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: 步骤 14 中的图像 1,3 Asus X200MA Motherboard Replacement: 步骤 14 中的图像 2,3 Asus X200MA Motherboard Replacement: 步骤 14 中的图像 3,3
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
结论
2等其他人完成本指南。
Alli Krininger
于11/11/19注册
391 声望
创作了3篇指南
团队
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019 的会员
IUPUI-STELLA-F19S2G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,251
