跳转到主内容
Asus X200MA Battery Replacement
你所需要的
  1. Asus X200MA Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Take two rubber caps off the back side of the laptop.
  4. Asus X200MA Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  5. Asus X200MA Battery Replacement: 步骤 5 中的图像 1,1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  6. Asus X200MA Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  7. Asus X200MA Battery Replacement: 步骤 7 中的图像 1,1
    • Slide the battery up and out.
结论
29等其他人完成本指南。
Vanessa Garcia
于01/22/15注册
1,763 声望
创作了6篇指南
团队
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G24
4 名成员
创作了8篇指南
8条评论
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - 回复
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - 回复
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 57
总计 35,309
