跳转到主内容
Asus X200CA-HCL 1104G Speaker Replacement
你所需要的
  1. Asus X200CA-HCL 1104G Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Speaker Replacement: 步骤 2 中的图像 1,1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Speaker Replacement: 步骤 3 中的图像 1,1
    • Unclip the connector that is located above touch screen
  4. Asus X200CA-HCL 1104G Speaker Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the speaker bar that is located beneath the touch screen.
    • Once removed carefully disconnect the clip to the left of the speaker.
结论
Svetlana Pimentel
于10/17/17注册
201 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 301
