跳转到主内容
Asus X200CA-HCL 1104G Motherboard Replacement
你所需要的
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: 步骤 2 中的图像 1,1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: 步骤 5 中的图像 1,1
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
结论
Svetlana Pimentel
于10/17/17注册
201 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 392
