跳转到主内容
Asus X200CA-HCL 1104G Headphone Jack Replacement
你所需要的
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: 步骤 4 中的图像 1,2 Asus X200CA-HCL 1104G Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
结论
Samantha Wahl
于10/17/17注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 115
