跳转到主内容
Asus X200CA-HCL 1104G Fan Replacement
你所需要的
  1. Asus X200CA-HCL 1104G Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Fan Replacement: 步骤 2 中的图像 1,1
    • The fan will be visible toward the bottom of the internals. It is semicircular with a small wire connected to the top of it.
    • Visually inspect the fan for any debris or blockage. If there is none, the fan probably needs to be replaced. To do that, we need to first disconnect the fan from the computer.
  3. Asus X200CA-HCL 1104G Fan Replacement: 步骤 3 中的图像 1,1
    • Disconnect the fan by gently pulling the connectors on the wire apart from each other.
  4. Asus X200CA-HCL 1104G Fan Replacement: 步骤 4 中的图像 1,1
    • Now, use the Phillips 1 screwdriver to unfasten the two screws holding the fan in place.
    • From here, the fan will lift easily out of the laptop.
结论
Samantha Wahl
于10/17/17注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 260
