跳转到主内容
Asus X200CA-HCL 1104G Battery Replacement
你所需要的
  1. Asus X200CA-HCL 1104G Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Battery Replacement: 步骤 2 中的图像 1,1
    • The battery will be easily visible towards to top of the internals. It is a long, black rectangle marked "Li-ion". Notice that the battery is currently secured by three screws. We will need to unscrew them in order to remove the battery.
  3. Asus X200CA-HCL 1104G Battery Replacement: 步骤 3 中的图像 1,1
    • You will notice that there are two gold screws and one silver screw holding the battery in place. Using the Phillips 1 screwdriver, remove the silver screw.
    • For the gold screws, pliers may be necessary. Be careful not to cut yourself on them; they can be finicky.
    • From here, the battery will lift easily out of the laptop.
结论
Samantha Wahl
于10/17/17注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 405
