跳转到主内容
Asus X200CA Wifi Card Replacement
你所需要的
  1. Asus X200CA Wifi Card Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus X200CA Wifi Card Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Wifi Card Replacement: 步骤 2 中的图像 1,1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Wifi Card Replacement: 步骤 3 中的图像 1,1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Wifi Card Replacement, Wifi Card: 步骤 4 中的图像 1,2 Asus X200CA Wifi Card Replacement, Wifi Card: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the 2 screws.
    • Use tweezers to separate the 2 coaxial connectors.
  5. Asus X200CA Wifi Card Replacement: 步骤 5 中的图像 1,1
    • Use fingers or tweezers to remove the wifi card.
结论
3等其他人完成本指南。
团队
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 974
