跳转到主内容
Asus X200CA Motherboard and RAM Replacement
你所需要的
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus X200CA Motherboard and RAM Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: 步骤 2 中的图像 1,1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: 步骤 3 中的图像 1,1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: 步骤 4 中的图像 1,1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: 步骤 5 中的图像 1,2 Asus X200CA Motherboard and RAM Replacement: 步骤 5 中的图像 2,2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: 步骤 6 中的图像 1,2 Asus X200CA Motherboard and RAM Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: 步骤 7 中的图像 1,2 Asus X200CA Motherboard and RAM Replacement: 步骤 7 中的图像 2,2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: 步骤 8 中的图像 1,1
    • Lift the motherboard/RAM out from the frame.
结论
7等其他人完成本指南。
团队
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 73
总计 8,655
