跳转到主内容
加入维修社区 - 创建账户
Asus X200CA Keyboard Replacement
你所需要的
  1. Asus X200CA Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus X200CA Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Keyboard Replacement: 步骤 2 中的图像 1,1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
结论
5等其他人完成本指南。
团队
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G2
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 1,185
