本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to replace the battery of the Asus X200CA. The battery is a 3Cells 3300 mAh 33 Whrs.
你所需要的
Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
Remove the black 14.5mm screw from the center of the bottom cover.
Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
即将完成!
结论
11等其他人完成本指南。
