跳转到主内容
Asus W2W-A1 Touchpad Replacement
你所需要的
  1. Asus W2W-A1 Touchpad Replacement, Keyboard: 步骤 1 中的图像 1,3 Asus W2W-A1 Touchpad Replacement, Keyboard: 步骤 1 中的图像 2,3 Asus W2W-A1 Touchpad Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Touchpad Replacement: 步骤 4 中的图像 1,2 Asus W2W-A1 Touchpad Replacement: 步骤 4 中的图像 2,2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Asus W2W-A1 Touchpad Replacement, Front Panel: 步骤 5 中的图像 1,1
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
  6. Asus W2W-A1 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,2 Asus W2W-A1 Touchpad Replacement, Touchpad: 步骤 6 中的图像 2,2
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  7. Asus W2W-A1 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
结论
Nolan Schock
于04/14/14注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G29
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 255
