你所需要的
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
Unscrew the 2 4 mm Phillips head screws by the battery.
Place your fingers or a spudger between the front panel and the rest of the laptop.
Pull upwards gently to detach the side you are grabbing.
Repeat on the other side until the panel easily peels off the laptop.
The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
Unscrew the 3 13 mm Phillips screws on the surface of the panel.
Unscrew the 4 mm Phillips screw beneath the panel.
Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
Unscrew the 5mm Phillips head screw that lies just above the D screw.
Remove the 2 4 mm, wide Phillips screws per speaker holding in the two speakers at the lower end of the device.
