跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Replace a broken hard drive or upgrade your hard drive to increase your storage space.
配件
没有特定配件。
  1. Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
  2. Grab the panel and lift upwards while pulling towards yourself.
    • Grab the panel and lift upwards while pulling towards yourself.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Remove the 3 4 mm Phillips upper screws holding the hard drive down.
    • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
  5. Pull the hard drive towards yourself to disconnect it from the laptop.
    • Pull the hard drive towards yourself to disconnect it from the laptop.
  6. Lift the hard drive upwards to remove it from the laptop.
    • Lift the hard drive upwards to remove it from the laptop.
结论
Nolan Schock
于2014年04月14日注册
501 信誉积分
创作了5篇指南
团队
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G29
4 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 186
