跳转到主内容
Asus Vivobook S500CA Touch Pad Replacement
你所需要的
  1. Asus Vivobook S500CA Touch Pad Replacement, Touch Pad: 步骤 1 中的图像 1,1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Touch Pad Replacement: 步骤 2 中的图像 1,1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 10mm screws and 7 5mm screws) around the perimeter of the back plate.
  3. Asus Vivobook S500CA Touch Pad Replacement: 步骤 3 中的图像 1,1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Touch Pad Replacement: 步骤 4 中的图像 1,1
    • Remove 9 5mm screws around the edge of the battery
  5. Asus Vivobook S500CA Touch Pad Replacement: 步骤 5 中的图像 1,1
    • Lift up the battery to reveal the battery terminal.
  6. Asus Vivobook S500CA Touch Pad Replacement: 步骤 6 中的图像 1,1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clips.
  7. Asus Vivobook S500CA Touch Pad Replacement: 步骤 7 中的图像 1,1
    • Remove the silver tape at the edge of the touch pad.
  8. Asus Vivobook S500CA Touch Pad Replacement: 步骤 8 中的图像 1,1
    • Disconnect the white ribbon labeled “TP” by pulling gently.
  9. Asus Vivobook S500CA Touch Pad Replacement: 步骤 9 中的图像 1,1
    • Remove 2 5mm screws from the hard drive casing.
  10. Asus Vivobook S500CA Touch Pad Replacement: 步骤 10 中的图像 1,1
    • Slide the touch pad out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 648
