跳转到主内容
Asus Vivobook S500CA Screen Hinges Replacement
你所需要的
  1. Asus Vivobook S500CA Screen Hinges Replacement, Screen Hinges: 步骤 1 中的图像 1,1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Screen Hinges Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • It may be helpful to lay out the screws in the orientation in which they are taken out, in order to help remember where they go.
  3. Asus Vivobook S500CA Screen Hinges Replacement: 步骤 3 中的图像 1,1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Screen Hinges Replacement: 步骤 4 中的图像 1,2 Asus Vivobook S500CA Screen Hinges Replacement: 步骤 4 中的图像 2,2
    • Remove 3 (.5 cm) phillips screws around the edge of the hinge. Repeat for other side.
  5. Asus Vivobook S500CA Screen Hinges Replacement: 步骤 5 中的图像 1,1
    • Disconnect the black and white wires from the “Aux” (white) and “Main” (black) ports
  6. Asus Vivobook S500CA Screen Hinges Replacement: 步骤 6 中的图像 1,2 Asus Vivobook S500CA Screen Hinges Replacement: 步骤 6 中的图像 2,2
    • Open the device to access the plastic casing over the hinges.
    • Remove the casing by lifting firmly. This step can be difficult.
  7. Asus Vivobook S500CA Screen Hinges Replacement: 步骤 7 中的图像 1,2 Asus Vivobook S500CA Screen Hinges Replacement: 步骤 7 中的图像 2,2
    • Remove 4 (.5 cm) screws from the hinge. Remove the hinge and follow steps in reverse order to reassemble and complete repair.
结论
Jermaine Carnell
于01/17/17注册
107 声望
撰写一个指南
一条评论
Hi.
The Asus X550C set screen (screen + flat cable) is compatible with Asus S500CA notebook? Anybody know response for me? Tks
Rodrigo Rodrigues - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,337
