跳转到主内容
Asus Vivobook S500CA RAM Replacement
你所需要的
  1. Asus Vivobook S500CA RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA RAM Replacement: 步骤 2 中的图像 1,1
    • Use a Philips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. Asus Vivobook S500CA RAM Replacement: 步骤 3 中的图像 1,1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA RAM Replacement: 步骤 4 中的图像 1,1
    • Push away the tabs on the left and right sides of the RAM cartridge to release the cartridge.
    • Another pair of hands will make the process easier.
  5. Asus Vivobook S500CA RAM Replacement: 步骤 5 中的图像 1,2 Asus Vivobook S500CA RAM Replacement: 步骤 5 中的图像 2,2
    • Slide the cartridge directly away from its housing.
终点
2等其他人完成本指南。
一条评论
You did not replace the RAM, nor give specifications on what RAM to replace it with (DDR3 1600 SDRAM DIMM etc)
Especially as it does not look like normal laptop memory (SODIMM)
facebook - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 3,200
