跳转到主内容
Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement
你所需要的
  1. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 2 中的图像 1,2 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 3 中的图像 1,3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 3 中的图像 2,3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 4 中的图像 1,1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Wifi card: 步骤 5 中的图像 1,3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Wifi card: 步骤 5 中的图像 2,3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Wifi card: 步骤 5 中的图像 3,3
    • Unplug the two small cords connected to the wifi card.
  6. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
  7. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 7 中的图像 1,3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 7 中的图像 2,3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: 步骤 7 中的图像 3,3
    • Unplug the Wi-Fi card from the motherboard and remove it from the device.
结论
团队
USF Tampa, Team S10-G3, Thompson Fall 2017 USF Tampa, Team S10-G3, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 1,556
