跳转到主内容
Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement
你所需要的
  1. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: 步骤 3 中的图像 1,3 Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: 步骤 3 中的图像 2,3 Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Slide the hard drive out of the SATA port and remove it from the device.
结论
Samuel Foster
于11/06/18注册
157 声望
创作了2篇指南
团队
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 789
