跳转到主内容
Asus Vivobook Flip 14 TP410U LCD Assembly Replacement
你所需要的
  1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement, LCD Assembly: 步骤 1 中的图像 1,1
    • Turn off the power and disconnected the AC cable from the laptop.
  2. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 2 中的图像 1,2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber covers for the two screws located at the bottom of the screen.
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
  3. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 3 中的图像 1,2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 3 中的图像 2,2
    • Excessive force may cause damage to connections.
    • Rotate the screen 360 degrees for ease of access.
    • Place the opening tool at the corner of where the screen meets the base of the laptop.
    • Pry open the screen along the edge until it is completely off the front cover.
    • Disconnect each appropriate connector while opening up the laptop.
  4. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 4 中的图像 1,2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 4 中的图像 2,2
    • Excessive force should avoided since damage may accrue.
    • Remove the cable that connects to the touch display, front camera, and motherboard.
    • Remove each piece of tape that holds down each cable.
  5. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: 步骤 5 中的图像 1,1
    • Have the new LCD display fully unboxed and ready to be used.
    • Remove the old LCD display.
    • The touch screen sensor is extremely fragile, make sure to not put excessive force on the cable while assembling.
结论
2等其他人完成本指南。
Dominic Bento
于03/22/22注册
326 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 55
总计 833
