跳转到主内容
Asus VivoTab Smart Camera Replacement
你所需要的
  1. Asus VivoTab Smart Camera Replacement, Motherboard: 步骤 1 中的图像 1,3 Asus VivoTab Smart Camera Replacement, Motherboard: 步骤 1 中的图像 2,3 Asus VivoTab Smart Camera Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Camera Replacement: 步骤 2 中的图像 1,3 Asus VivoTab Smart Camera Replacement: 步骤 2 中的图像 2,3 Asus VivoTab Smart Camera Replacement: 步骤 2 中的图像 3,3
    • Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
    • Remove the silver plate that sits on top of the camera lens.
  3. Asus VivoTab Smart Camera Replacement: 步骤 3 中的图像 1,3 Asus VivoTab Smart Camera Replacement: 步骤 3 中的图像 2,3 Asus VivoTab Smart Camera Replacement: 步骤 3 中的图像 3,3
    • Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
  4. Asus VivoTab Smart Camera Replacement: 步骤 4 中的图像 1,2 Asus VivoTab Smart Camera Replacement: 步骤 4 中的图像 2,2
    • Gently pull outward on the ribbon to with tweezers to disconnect it.
  5. Asus VivoTab Smart Camera Replacement: 步骤 5 中的图像 1,3 Asus VivoTab Smart Camera Replacement: 步骤 5 中的图像 2,3 Asus VivoTab Smart Camera Replacement: 步骤 5 中的图像 3,3
    • Peel back the tape covering the ribbons.
  6. Asus VivoTab Smart Camera Replacement: 步骤 6 中的图像 1,3 Asus VivoTab Smart Camera Replacement: 步骤 6 中的图像 2,3 Asus VivoTab Smart Camera Replacement: 步骤 6 中的图像 3,3
    • Unplug the 3 ribbons by pulling outward on them with a pair of tweezers.
  7. Asus VivoTab Smart Camera Replacement: 步骤 7 中的图像 1,3 Asus VivoTab Smart Camera Replacement: 步骤 7 中的图像 2,3 Asus VivoTab Smart Camera Replacement: 步骤 7 中的图像 3,3
    • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
    • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  8. Asus VivoTab Smart Camera Replacement: 步骤 8 中的图像 1,2 Asus VivoTab Smart Camera Replacement: 步骤 8 中的图像 2,2
    • Remove seven 3.7 mm Phillips #00 screws.
    • Remove one 2.7 mm Phillips #00 screw.
  9. Asus VivoTab Smart Camera Replacement: 步骤 9 中的图像 1,2 Asus VivoTab Smart Camera Replacement: 步骤 9 中的图像 2,2
    • Slide the tweezers under the motherboard and lift up to remove the motherboard.
  10. Asus VivoTab Smart Camera Replacement, Camera: 步骤 10 中的图像 1,1
    • Flip the motherboard over and lay it flat on a surface
  11. Asus VivoTab Smart Camera Replacement: 步骤 11 中的图像 1,2 Asus VivoTab Smart Camera Replacement: 步骤 11 中的图像 2,2
    • Use tweezers to gently lift and remove the camera from the motherboard.
结论
Zach Hatten
于10/06/16注册
548 声望
创作了4篇指南
团队
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 304
