简介
If your tablet's battery will not hold a charge, this guide will show you how to replace the battery in 13 quick and easy steps.
你所需要的
Remove the tablet from the attached keyboard.
To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
在这个步骤中使用的工具:Tweezers$4.99
Rotate the Tablet clockwise, so that the motherboard is facing away from you.
Remove the eleven 0.79 mm #000 screws around the motherboard with the Phillips #000 screwdriver.
Remove the two wire connection on the right side of the tablet with the pointed precision tweezers.
6等其他人完成本指南。
一条评论
Hi...Im trying to disconnect battery and reconnect like pics above to try a reset from black screen of death after updates...I have black screen..it was working fine until then..now I dont even get a power light to show its charging????
