简介
When removing the battery, it may get damaged. The battery is rechargeable however may need replacement if it is broken.
你所需要的
Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
Disconnect the battery from the motherboard by pulling the side of the black plastic up.
To reassemble your device, follow these instructions in reverse order. You will need adhesive to keep the battery stuck if the tape stops working.
2等其他人完成本指南。
