跳转到主内容
加入维修社区 - 创建账户
Asus VivoTab Note 8 Back Panel Replacement
你所需要的
  1. Asus VivoTab Note 8 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 Back Panel Replacement: 步骤 2 中的图像 1,2 Asus VivoTab Note 8 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 Back Panel Replacement: 步骤 3 中的图像 1,1
    • After pulling the panel off, put it to the side.
结论
Ryan Spencer
于09/21/18注册
756 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 669
