跳转到主内容
Asus VivoBook X540SA-BPD0602V Keyboard Replacement
你所需要的
  1. Asus VivoBook X540SA-BPD0602V Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: 步骤 4 中的图像 1,1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: 步骤 6 中的图像 1,1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
结论
2等其他人完成本指南。
Ziyad Alharbi
于10/18/17注册
118 声望
撰写一个指南
团队
USF Tampa, Team S1-G111, Cagle Fall 2017 USF Tampa, Team S1-G111, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G111
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 39
总计 2,663
