跳转到主内容
配件
  1. First of all you need to remove the 10 screws holding the laptop together. Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly. Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
    • First of all you need to remove the 10 screws holding the laptop together.
    • Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly.
    • Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
  2. Once you open it, it should look like this. You need to unscrew the only screw (marked in red) to be able to remove the HDD. When you do that, just unscrew the 4 screws attatching the HDD to the bracket and replace it with the new one.
    • Once you open it, it should look like this.
    • You need to unscrew the only screw (marked in red) to be able to remove the HDD.
    • When you do that, just unscrew the 4 screws attatching the HDD to the bracket and replace it with the new one.
结论
2等其他人完成本指南。
Simeon Brankov
于2020年11月08日注册
3,256 信誉积分
创作了31篇指南
2条评论
Pls. Do more tutorial like this. It is very helpful to lack of knowledge person ?..
Would you mind to complete your tutorial regarding disassemble / assemble of this laptop model ?
For example : processor replacement
Heat sink replacement LCD replacement
Battery replacement
Hinges replacement
Thanks In Advance !
More Power !
Gilbert Gutierrez - 回复
Hello,
Im glad that you found the information useful. Unfortunately this laptop is no longer with me, if I come across the same model again, Ill be sure to make a more advanced tutorial.
Thank you and have a nice day :)
Simeon Brankov -
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 13
过去的30天: 51
总计 457
