跳转到主内容
Asus VivoBook X540N HDD to SSD Replacement
你所需要的
  1. Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: 步骤 1 中的图像 1,3 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: 步骤 1 中的图像 2,3 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: 步骤 1 中的图像 3,3
    • First of all you need to remove the 10 screws holding the laptop together.
    • Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly.
    • Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
  2. Asus VivoBook X540N HDD to SSD Replacement: 步骤 2 中的图像 1,3 Asus VivoBook X540N HDD to SSD Replacement: 步骤 2 中的图像 2,3 Asus VivoBook X540N HDD to SSD Replacement: 步骤 2 中的图像 3,3
    • Once you open it, it should look like this.
    • You need to unscrew the only screw (marked in red) to be able to remove the HDD.
    • When you do that, just unscrew the 4 screws attatching the HDD to the bracket and replace it with the new one.
结论
2等其他人完成本指南。
Simeon Brankov
于11/08/20注册
6,045 声望
创作了49篇指南
4条评论
Pls. Do more tutorial like this. It is very helpful to lack of knowledge person ?..
Would you mind to complete your tutorial regarding disassemble / assemble of this laptop model ?
For example : processor replacement
Heat sink replacement LCD replacement
Battery replacement
Hinges replacement
Thanks In Advance !
More Power !
Gilbert Gutierrez - 回复
Hello,
Im glad that you found the information useful. Unfortunately this laptop is no longer with me, if I come across the same model again, Ill be sure to make a more advanced tutorial.
Thank you and have a nice day :)
Simeon Brankov -
Sorry, I tried to replace it and the bios does not recognize it.
David - 回复
Hello,
This can indicate a problem with the SSD itself and/or the drivers on your laptop. Have you tried to load the drivers manually during Windows installation?
Simeon Brankov -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 46
总计 1,705
