跳转到主内容
Asus VivoBook X202E-DB21T Hard Drive Replacement
你所需要的
  1. Asus VivoBook X202E-DB21T Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Asus VivoBook X202E-DB21T Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 3 中的图像 1,2 Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 Asus VivoBook X202E-DB21T Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 7 中的图像 1,2 Asus VivoBook X202E-DB21T Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 957
